With the PRO plan can I create 2 bases and each base store 20GB?
754 1
Glia_GLIA
I’ll update to pro plan but before that I need to take a question. In the PRO Can I store 20GB on each base ?
I needed 2 bases each with 20 gb
With this plan I can have 2 bases and each of them store 20Gb ?
Dear @Glia_GLIA
Yes, it will give you 20 GB for each base.
