Work Time attendance system
1766 2
Juraj_Marko
Hi I want build attendance system tracking time to work and out of work
I want to use FORMform
where you can pick Name and slide checkbox IN. After work pick Name again and slide checkbox OUT.
The problem I have is how to get the OUT record in some line where the IN record is so I can make formula and calculated the time?
table
Estelle73
Hi @Juraj_Marko I’ve just published a tutorial on how to fill in an Airtable time tracking sheet via QR Code: when scanning the QR code, it updates the clock OUT field for the corresponding clock IN record. It is based on an integration between Ubiqod and Airtable via Zapier. Would you be interested if there was a native integration between Ubiqod and Airtable?
Denis_P
Hello Juraj, We have a predeveloped HRMS system where you can manage a daily Time attendance system. Enhances your business productivity by keeping track of employee working hours and job attendance. Visit our attendance management system for more info.
