Automation - Less than and Greater than
Topic Labels: Automations
1150 3
mikeeTHINK
For the automation above, I kept getting an error OR inaccurate output. When I would test it out and submit a 90% score, it keeps creating a record as if the score was less 89.99
Sara
8 - Airtable Astronomer
Hi, I don't know if I'm right, but is your score column in percentage? Otherwise, the condition should be 0.90 and 0.8999 because you use a percentage, not a whole number.
3 Replies 3
Sara
mikeeTHINK
Thanks Sara! This solved my problem~
Sara
No problem 🙂 have a great day
