Automation not work anymore
  • June 21, 2023
  • 13 views
Forum|alt.badge.img+16
Hi, I used this automation for 1 year, and it has always worked, but today it started to fail to run. It is just an easy automation; when my customers fill out a form, a record is created in a table, and the automation sends an email.
What can I do to solve the problem? I also tried to create again the automation, but nothing!
Thank you
Forum|alt.badge.img+24
  • June 22, 2023
hi,
Was there a similar problem before and has it recurred?
You may want to contact support.
Solved: Attachments in Send Email Automation not Working a... - Airtable Community
