Difference in the way Find Automation Works
Topic Labels: Automations
317 0
Maximilian_Sehn
Hey, we are currently experiencing the issue that a automation changed the way it works. The Find Records Automation used to just fail if it searched for a empty field now it gives us back the maximum Amount of Records it can find(100).These are also not empty in the field that is searched for. Is this a intentional change or just a bug?
0 Replies 0
