- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
‎May 18, 2024 03:27 AM
I have table A and table B.
When a record in table A is created, I have an automation that creates the same record in table B. However, the primary column in table B stays blank. How can I fill the primary column in table B with the primary column value of table A?
- Mark as New
- Bookmark
- Subscribe
- Permalink
‎May 19, 2024 09:55 PM
Are the 2 records linked? I have tables that use a formula to populate my primary field with the name in the linked field...
- Mark as New
- Bookmark
- Subscribe
- Permalink
‎May 22, 2024 04:32 AM
No, its not linked.
I work in property management company.
I want to have "tasks" table for general tasks and "faults" table for faults in the properties. When I create new record in the "faults" table i want it to create the same fault in the "tasks" table and if I change the status for that fault in the tasks table it will change the status in that record in the faults table as well.
Is it possible?
- Mark as New
- Bookmark
- Subscribe
- Permalink
‎May 22, 2024 01:45 PM
I'm sure there IS a way to do that, but I'm wondering if it might be more complicated than it needs to be? This could maybe be done in as little as 2 tables, allowing for a complete picture of everything that needs doing using views. This would prevent needing to duplicate records and potential errors.
Threw this together as a quick example: https://airtable.com/appqpn8HdoLV8opeM/shriZx2HEdJYc2zcT
