Scripting problem
Topic Labels: Automations
1774 1
Matthieu_Chatea
I have a problem with a script that worked and all of a sudden, stopped to work:
"App Name" is a linked record field. "Add App On Sign Up" is another linked record field. When a value is inserted in "Add App On Sign Up", I need this value to be inserted in "App Name" (inserted, meaning adding a value, not replacing a value to "App Name".
Anyone has a better script to propose?
The error message is:
Error: Field "fldGBiazYCpFzbsOv" cannot accept the provided value.
    at main on line 12
Field "fldGBiazYCpFzbsOv" is the field id of App Name
const table = base.getTable("Members");
const query = await table.selectRecordsAsync();
for (const record of query.records) {
  const appNames = record.getCellValue("App Name");
  const addAppOnSignUp = record.getCellValue("Add App On Sign Up");
  if (appNames && addAppOnSignUp) {
    const updatedAppNames = appNames.map(appName => appName).concat(addAppOnSignUp);
      "App Name": updatedAppNames
Matthieu_Chatea
I solved it by changing the script to perform an update in the Apps table and not directly in the Members table
Matthieu_Chatea
