🤞 Triggered Facebook Automation Post Content help
Topic Labels: Automations
333 4
WayneGrantham
Happy Day to all, can't wait to see the group support for something I'm missing.
Info: I have created an automation to post to Facebook.
I have trigger set to run once a day, with conditions = 1 based on formula in field.
I need help on the Actual Message to post.
I hit the blue + and added Copy field and it only posted the actual field ID on the text post.
Not the "Contents" of Copy field.
I also am getting an error on the attachments field when adding the ContentImage field to send over the "picture".
I have scoured through the forums and on youtube, but I seem to be missing one important step of HOW TO ADD to the message content in Actions Section.
TLDR: Need help with the Message Section of Post to FB action.
What to put in MSG box.What to put in MSG box.
4 Replies 4
You actually aren't telling it which records to send to Facebook.
After a scheduled time trigger, you need to add a "Find Records" action to find the records that you want to take action on.
Then, you will need to loop through the results with a "repeating group", in order to perform actions on each record that was previously found.
However, note that Airtable does not allow you to combine repeating groups with conditional actions, and it looks like you want to perform conditional actions in your automation.
That is not currently possible with Airtable's automations.
If you need to create an advanced automation that combines conditional actions with repeating groups, you would need to turn to Make's Airtable automations and Make's Facebook integrations.
Make can be challenging to learn, so if you’ve never used Make before, I’ve assembled a bunch of Make training resources in this thread.
For example, here is one of the ways that you could instantly trigger a Make automation from Airtable.
Thank you for the feedback.
After the find records part,
Will the blue + bring in the actual data from cell Copy?
Or will the message part need something more.
Yeap it would and your automation would look something like the screenshot below (substituting the 'Send email' action with your FB action of course)
Link to base
We're skipping over a couple of concepts though, so if you hit a wall and could use someone to walk you through it feel free to schedule a free half hour call here!
@WayneGrantham
Yes, that is correct. You would use the blue plus sign to bring in data from each record.
