I am trying to add all records from a view in a separate table to a field for all records in a view on another table.
let TBTable = base.getTable(‘Technical Comments for VB’);
let TBView = TBTable.getView(“Shared to All Trigger”)
let TBQuery = await TBView.selectRecordsAsync();
let TBRecord = TBQuery.records;
let VBTable = base.getTable(‘Verifier / Trainer Body’);
let VBView = VBTable.getView(“Verifier Bodies (Public List)”)
let VBQuery = await VBView.selectRecordsAsync();
let VBRecords = VBQuery.records;
let d =
VBRecords.forEach(c => d.push({id: c.id}));
await TBTable.updateRecordAsync(TBRecord.id,{‘Verifier Body’: d});
output.markdown(’# Done :rocket: ’)
I am getting an error that the record is not defined. Can someone help?
Thanks,
