Render more than 100 data points (using axios in react.js)
Topic Labels: API
1215 1
Tiago_Sanchez
Hi there,
Would love to get more than 100 data points in the state of my app so that I can keep it on the state of my app.
How should I go about doing that?
This is my take for the first 100 data points and it works as intended.
How should I get the other 100+ using the offset?
Thank you for the help,
Tiago_Sanchez
I know that this can be done using airtable.js.
base(‘collab DB’).select({ view: ‘collab 5.0 korea’ })
.eachPage(
(records, fetchNextPage) => {
//all this is to solve for a problem when I have more than 100 items
allStartups = [
records,
…allStartups]
.reduce((acc , cv) => {
return acc.concat(cv)
fetchNextPage();
I have done it and it works. However I would prefer to do it using axios. Again, any help here?
