Combining IF and LEFT formula -- not working.
878 3
GrahamW
Hi all, Im struggling to figure out why a formula in my table produces a blank response vs the intended result...
I can provide more context if needed but suspect the error is more obvious to some of you and context is irrelevant.
LMK if context is needed.
The formula is:
IF({Junction}=1,LEFT({Status},1) & [Product}," ")
'Junction' field can have only two possible results 1 or zero. I would like that if a record contains a 1 in this field, that this new field formula produces a text string that combines the status and product, (eg "Ongoing - Product A")
It's not doing that though... it's producing just " ")
What have I got wrong? 😞
3 Replies 3
Ben_Young1
10 - Mercury
10 - Mercury
Hey @GrahamW
Based on the details you provided, I created the following:
Here's the formula that I used:
    {Junction},
        {Status},
        TRIM({Status}) & IF(
            {Product},
        {Product},
        TRIM({Product})
I'm actually a bit surprised that your formula field let you create the field with that formula you provided in your post because your Product field name is wrapped with mismatched curly/square brackets.
Ben, Im giving you kudos, but want you to know that the error was me... I was referencing the wrong GD field.
The bracket you reference was a transcription error on my part, otherwise it works if I input the right field. Thanks for trying, sir.
GrahamW
Ben, this is the result.. and what I was looking for (sensitive info covered)
but if you know how I can get it to look like this, it would be EVEN BETTER
One field that isn't visible that is a commonality amongst these records is the one that lists the junctional relationship. Mentioning that as I believe that it is an important detail to achieving the look
