Custom Formula Help
711 2
v1_oh_n0
I am looking for a custom formula to help me solve the following.
Basically: If text in column A is true then add numbers in column B + 50 otherwise null.
If {inspection} contains "oil change" then add {engine hours} + 50.0
The problem I have is finding the correct way to prevent all engine hours having 50 added to it so I can determine when the next oil change is due.
Would this be possible?
I'm not entirely sure what you're doing, but I used the following formula to get this result:
  FIND(
    "oil change",
    LOWER(Name)
  {Engine Hours} + 50,
  {Engine Hours}
Having a problem accepting
LOWER(Name)
 What should "name" be?
