- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
‎Aug 31, 2022 11:47 AM
Hi there! This is a very newbie question, but is there a formula for cutting numbers out of a string? For example, if I have the value
01 Lorem ipsum
and I want it to read
Lorem ipsum
what formula would I use?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
‎Aug 31, 2022 01:42 PM
This is an important distinction between Ben’s formula and mine. Mine only removes digits at the start of the string. Ben’s removes all digits everywhere in the string.
Note that this can be problematic. What if there are two or more spaces next to each other that were in the original string that did not have digits between them? This formula will remove those additional spaces as well.
There are a few other options. Instead of using '\s{2,}'
you could also use ' +'
to find one or more spaces and replace them with a single space. This would have the same effect. It depends on what you find easier to read and how much work you want the computer to use.
However, another option would be when searching for digits to search for one or more digits and zero or more trailing spaces in the initial REGEX_REPLACE: '\d+ *
. This would leave any consecutive spaces that were supposed to be there unaffected.
I agree. A regex tester is essential to learning regex. However, I find that different regex testers have different helps, so if one doesn’t work for you, try a different website.
There are many ways to do things in REGEX. Testing with a wide variety of inputs is essential to getting the result you want.
- Mark as New
- Bookmark
- Subscribe
- Permalink
‎May 30, 2023 06:43 AM
How does one also extract the numbers that are mixed with texts in the middle?
- « Previous
- 1
- 2
- Next »
