Save the date! Join us on October 16 for our Product Ops launch event. Register here.
Jul 24, 2024 10:58 AM
I am trying to generate a formula where:
1. If date in field x is greater than 1953, then 1 is put in field z
OR
2. If checkbox is checked in field y, then 1 is put in field z
I came up with this formula
IF(OR({NO DIGITAL} = 0), ({CODE-DATE} > 1953), "1")
However, this is producing a statement that reads 'true' if {CODE-DATE} > 1953, and '1' if {NO DIGITAL} = 0 (that is to say, box in {NO DIGITAL} is checked)
Any idea why this is happening or how to get the results I want?
Jul 24, 2024 12:27 PM
Hi @K_B1,
here we have a simple syntax error. The or statement only looks at {NO DIGITAL} = 0. As a result you have the following:
Assuming that you want to print a 0 if both statements are not true, the formula should look like this:
IF(OR({NO DIGITAL} = 0, {CODE-DATE} > 1953), 1, 0)
Let me know if it works!
Best, Patrick @Monino Solutions
Jul 24, 2024 01:34 PM
what if I want it to do nothing if both statements are false?
Jul 24, 2024 01:35 PM
Got it working. Thanks!
Jul 24, 2024 01:41 PM
Then the formula should include an empty string like below:
IF(OR({NO DIGITAL} = 0, {CODE-DATE} > 1953), 1, "")
Let me know if that works.
Best,
Patrick
