Jun 09, 2022 09:08 PM
I’m starting on airtable and I can’t find the right formula to perform an operation.
I would like to extract the link in the second column IMAGE to insert it at the planned location in the third column JSON.
Can someone help me with this ?
Thank you :slightly_smiling_face:
Solved! Go to Solution.
Jun 09, 2022 10:37 PM
Hi Heav, could you try:
'{"logo": {"original": "' & {Image} & '" }}'
Jun 09, 2022 11:08 PM
Wow, it looks so simple and it works, thank you very much :slightly_smiling_face:
