Help with if then formula
221 1
AmandaC1121
I am needing help creating a formula.
It would be if (15% referral says no then it would calculate the daily rate times 15%), if (15% referral says yes then it would be daily rate)
Ben_Young1
10 - Mercury
10 - Mercury
Hey @AmandaC1121
Is this along the lines of what you're looking for?
    {15% Referral} = "No",
    {Daily Rate} + ({Daily Rate} * .15),
        {15% Referral} = "Yes",
        {Daily Rate}
It's worth noting that this formula will return nothing if the 15% Referral field returns empty.
If you'd like for the formula to default to just returning the Daily Rate, you could use this:
    {Daily Rate}
You'll want to confirm that your formula field's formatting configuration is set properly:
Ben_Young1
10 - Mercury
10 - Mercury
Hey @AmandaC1121
        {Daily Rate}
    {Daily Rate}
