May 27, 2021 06:29 AM
ColA has 3 different transaction numbers.
The first always starts with TEX followed by numbers.
The second is always just numbers.
The third is always blank.
I need a formula that will look at ColA
If ColA has TEX, in ColB put Text Me
If ColA does not have TEX, in ColB put Call Me
If ColA is blank, in ColB put Do Not Contact
May 27, 2021 07:32 AM
Something like this?
You can use nested IFs as such
IF(LEFT(field,3) = "tex" , "Text Me" , IF(field , "Call Me" , "Do Not Contact"))
May 27, 2021 10:20 AM
This did not work. All are returning “Call Me”.
IF(LEFT(extra,3) = “tex” , “Text Me” , IF(extra , “Call Me” , “Do Not Contact”))
May 27, 2021 10:56 AM
It is case sensitive, so if your data is always going to be “TEX” (uppercase), then you can just do:
IF(LEFT(extra,3) = 'TEX' , 'Text Me' , IF(extra , 'Call Me' , 'Do Not Contact'))
Jun 03, 2021 09:18 AM
If the case won’t be consistent then you could use ‘lower’ in your comparison
IF(extra, IF(LOWER(LEFT(extra,3)) = "tex" , "Text Me" ,"Call Me") , "Do Not Contact")
I needed to switch the order around because lower would error when called on the blank result of a left function
