Sep 19, 2020 12:05 PM
I have records that are automatically created in my base. Some of them end in the phrase “(X of Y)” to indicate they are one of many. Others do not have this tag at all.
I need help creating a formula that removes all instances of this parenthetical count. This would give me ability to group all records with identical names:
Kelly’s Record (1 of 2)
Kelly’s Recors (2 of 2)
----> all turn in to “Kelly’s Record”
However, I need the formula to leave unique records unaffected:
Kelly’s New Record
—> Kelly’s New Record
Solved! Go to Solution.
Sep 23, 2020 10:36 AM
You can wrap it in an IF() to only apply to titles with a (
IF(FIND(' (', Name), TRIM(LEFT(Name, FIND(' (', Name))), Name)
Sep 19, 2020 01:11 PM
Assuming that the phrase always starts with (
, and no other part of the text will have parantheses, you could use this formula:
LEFT({Field name}, FIND({Field name}, ' ('))
^ Its selecting all the text to the left of the first time [space](
appears
Sep 21, 2020 03:18 PM
Does not seem to work. Leaves every field blank, even though the formula doesn’t return an error
Sep 21, 2020 03:21 PM
Is {Field name}
a Lookup or Rollup field? If so, you can fix it like this:
LEFT({Field name}&'', FIND({Field name}&'', ' ('))
Sep 21, 2020 03:43 PM
Nope - tried that and no dice. It is a text field.
Sep 21, 2020 03:50 PM
Sorry, I had the Find formula backwards:
TRIM(LEFT({Field name}, FIND(' (', {Field name})))
(I have now wrapped everything in a TRIM() to remove any trailing space at the end)
Sep 23, 2020 10:23 AM
Ok Awesome - this works IF there is a title that has a Parenthetical.
However, for titles that do not have a parenthetical, it returns an empty text field.
Is there a way to apply this formula only if there is a parenthetical, and otherwise simply copy over the title as is?
Sep 23, 2020 01:03 PM
Thank you! This worked perfectly
