Sum the two smallest values between three values
247 2
ChaumeilDigital
I need to sum the two smallest values between three values.
Example:
- Value 1: 10
- Value 2: 20
- Value 3: 30
The two smallest values are "Value 1" and "Value 2".
How to do this via a formula (or other
Alessio_Monino
9 - Sun
9 - Sun
Hi @ChaumeilDigital,
This is a possible solution to create the calculation - you could create a formula that sums up all three values, then subtracts the largest value among the three using MAX() -> this gives us the sum of the two smallest values among the three (because it subtracts the largest)
I hope this helps!
Website: https://alessiomonino.com
Calendly: https://alessiomonino.com/contact
Email: alessio.monino@gmail.com
Alessio_Monino
9 - Sun
9 - Sun
I hope this helps!
Thanks for your quick reply !
