Is there a sequential order when a new record is created through a Form view? Can you define/control the order?
Using Formula to Create Autonumber
Best answer by Jeremy_Oglesby
Thanks, I don’t think I phrased the question very well. I’ve set up my primary formula with this: ‘EV-’&REPT(‘0’,{Leading Zeros}-LEN({Autonumber}&’’))&{Autonumber}
When a user submits a new record via a form view, the formula does pick up the 'Leading Zeros value. Can I set a static value for the Leading Zero in the formula?
I think the answer here is yes, based on what you are saying and the formula you showed us. I’m not sure what your {Leading Zeros} field is holding, but I assume it’s just a number representing the total length you want the numeric portion of your ID’s to be.
So if you want the numeric portion of your ID’s to always be 5 digits long…
00001
00002
02308
etc...
then you can just replace that reference to {Leading Zeros} with the number 5 – your formula will continue to behave the same way.
Is that what you were asking?
Login to the community
No account yet? Create an account
