Zapier: Exact same formula not working
  • January 26, 2022
  • 25 views
Hey guys!
I have the exact same formula on Airtable and Zapier, it’s working on Airtable but not working on Zapier, what am I doing wrong?
(The purpose of the formula is to check if my “Shopify ID (Produto)” is inside a bunch of ID’s that I get from Shopify)
The formula:
Thanks a lot
  • January 27, 2022
In Integromat, you can just copy & paste a normal Airtable formula into the search formula field.
However, in Zapier, you’ll need to surround your value token (i.e. the variable value that you’re using in Zapier) with <TriggerValue>.
More details on this page, under the section entitled “Write a search formula”:
