Calendar view in interface - more items not visible
1094 3
Andrea_Borriero
Dear all,
I'm using the calendar in the interface; in the month view, if there are more items, accondingly to the zoom setting, only some items are visible, while others are not visible, even though the label "+ x more" is present.
Even by clicking in the day the other items appear only for less than 1 sec, after the click.
Are there some ways in order to see the title of the items withuot open the right summarize column?
Thank you.
Best regards.
A. Borriero
18 - Pluto
18 - Pluto
@Andrea_Borriero Be sure to report this as a bug to support@airtable.com
3 Replies 3
Interesting, it's happening for me too.  In the gif below, I'm just clicking on the "+" button once, and then it rest of the records show up and then disappear immediately
Tried it in both Chrome and Firefox on a MBP
Only seems to happen in the Interface calendar view too; normal calendar view seems fine
18 - Pluto
18 - Pluto
Dear Scott,
thank you for the advice; actually in the calendar of the DATA section the items are fixed and visible by clicking; only in the interface that happens.
Best regards.
A. Borriero
