Grid Interface Element - some layout questions
  • September 11, 2023
  • 37 views
HI,
I'm implementing a base for approx. 20 users and for security and confidentiality reasons I need to use a grid element in the interface to display each user's  records .
While the grid is working correctly,  I have some formatting questions that I have been unable to figure out the answer to.
1) while the user can copy/paste from the grid out to Excel , is there any way to copy out the column headings as well (as in a CSV Export from the data layer) ?
2) As this base is replacing a spreadsheet, I'm displaying 16 consecutive columns of numeric values. Is it possible to format any of these columns to make it easier to read ? ie Bolding, changing background colour of a column etc ?
3) Is there any way to hide the Base's Key field in the grid element ?
Any help or suggestions appreciated .
John
None of these 3 things are available with Airtable's interfaces, but all 3 of these things are available with Noloco's advanced interfaces for Airtable. Noloco is a frontend portal/interface app that communicates with Airtable on the backend.
I give a step-by-step tutorial of Noloco on this episode of the BuiltOnAir podcast.
The CEO of Noloco gave a demonstration of his product on this Airtable podcast episode.
I also presented a full one-hour webinar on Noloco called Building a Client Portal on Noloco powered by Airtable.
p.s. If you have a budget for your project and you’d like to hire an expert Airtable consultant to help you with any of this, please feel free to contact me through my website: Airtable consulting — ScottWorld
