- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
‎Feb 12, 2025 08:23 AM
Trying to get my dashboard interface to show a graph with multiple Y axis that links to a record picker. So far, I've only been able to get 1 Y axis, I can get multiple Y axis when I don't use a record picker though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
‎Feb 18, 2025 11:24 AM
Hmm, you are correct that it doesn't appear you are able to have multiple axes when using a record picker. If having multiple axes is important to you, I suggest using the "dashboard" interface layout and utilizing dropdown filter options to allow the user to select the corresponding timeframe they need. It looks like from your screenshots that you have a desire to allow people to select the month and year. You can achieve this by creating a formula > single select output field for date with the formula:
This will allow you to create the dropdown filter in the dashboard view to accomplish virtually the same thing, with the multiple axes. Hope this helps!
