Overview In Interface is Not shown for everyone
202 5
moverall
I am trying to create an Overview with Buttons for Forms.  When I finish it, it looks normal, but when I have others test it, it does not appear correctly.
Here is what I see:
Here is what I would like to see:
 I have done the following:
Clear the cache and cookies.
Used multiple browsers (same result)
This way on both Mac and PC
Changed credentials of users accessing the site.
Same result for any table that I have built with Overview
Any assistance is appreciated
 Thank you,
5 Replies 5
Have you already clicked on the "Publish" button in the upper right to publish the changes to your users?
moverall
Yes I have.  I have removed and re-added the buttons and published it as well and I ended up with the same result.
I would send an email to support@airtable.com to tell them about the issue you're experiencing, and let us know what they say!
moverall
Thank you for the response, I will do this now.
Hmm that's super interesting.  I was thinking maybe it was to do with permissions and so tried to create an Overview with a Form, then invited a user with read-only access to it but the button still showed up fine
I'd love to take a look at this for you if you could DM me an invite to your base!
