Able to have a field auto-copy on click?
703 1
travmilne
Looking to be able to have a field that auto-copies (added to clipboard) when I click on the cell. Saving me the CTRL+C keyboard shortcut.
Possible? Maybe with scripting / extensions?
This cannot be done with Airtable scripting. Airtable scripts do not have access to the clipboard.
It could be done with an extension, but it would only work when the extension is open, and the effort to code it would far outweigh the effort to press Ctrl-c every time.
