Chrome and Edge security certificate issue
1800 2
Joe_Martinez
Hello: for several days I cannot access Airtable on my work desktop due to this certificate error. I cleared my cache, cookies, and all browsing history. I also uninstalled Chrome and reinstalled, and still receive the same message after.
Note, I am also getting this same error with Microsoft Edge.
Have I been hacked? I cannot post a screenshot, but on my Chrome screen it says "the server could not prove that it is airtable.____; its security certificate is from synchronic . uat. edu. "
Thank you.
Does that URL mean anything to you?
If this only happens at work, I would talk to your work IT department about this. Chances are there was a change to some network setting that is affecting how you access certain outside sites on your work machine.
Joe_Martinez
Thank you for your help. Based on your feedback I figured out that indeed this was definitely a network issue. I very much appreciate your help.
