HR base and permission levels
Topic Labels: Base design
114 1
dianebell
Hi
When using the HR base for recruitment purposes, can only set only certain people in the organization to see specific aspects (permission levels) i.e. someone you have recruited and is now internal you would not want seeing who applied for their position; people in mid-level positions, you would not want them to see senior-level positions.  Can you only allow certain people to see certain positions e.g. for shortlisting purposes?
Thanks
I think you'd have to make sure they don't have access to the base, and give them access to specific Interfaces that you'd set up for them
You could use shared Views as well for this, but I think the permissions for those aren't as granular, so a view you shared with Person Y could be viewed by person X
