Jan 31, 2022 03:44 AM
Hello people, hope you can help me to solve my problem.
I’m currently using a formula to substitute some character for cleaning my cell :
SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(SUBSTITUTE(Telephone,".","")," “,”"),"-",""),"(",""),")","")
and after this step , i’m using an other formula :
IF(LEFT(Telephone,1)!=“0”,CONCATENATE(“0”,Telephone),Telephone)
it works perfectly but the question is : how can i do the same thing in one formula ?
For exemple :
(06-07-45)43.56 26 i want 060745435626
(6-07-45)43.56 26 i want 060745435626
Sorry for my english, i’m french :grinning_face_with_smiling_eyes: and thank you for your answers.
Jan 31, 2022 12:00 PM
Simplify your formula by using REGEX to remove “everything that’s not a digit” ([^\\d]
LEFT(REGEX_REPLACE(Telephone, "[^\\d]", ""), 1) != "0",
"0"
) & REGEX_REPLACE(Telephone, "[^\\d]", "")
^ the above could probably be written more efficiently with a single line of REGEX, but the above will work.
Feb 01, 2022 01:41 AM
It’s perfect ! Thank you a lot !
Feb 01, 2022 03:03 AM
thanks my issue has been fixed.
