May 12, 2020 01:20 AM
Hello everyone, I am new to airtable, have been trying out a possible solution for my company for a few days now.
Currently I have a table created with all the data I need. I have just created multiple Views with the results I want each collaborator to see and edit. What I don’t want is for them to see all the Views I have created.
I know this is not possible(or is it?), but is there any other I could possibly go around it?
What I am trying to do is create a database of Cars(car dealership) that are ready to be delivered. But they go through a process(the one I am creating right now). That said, I have a single table with all the fields I need to be filled. I have then created multiple views only showing the data each department needs to fill. I just don’t want collaborators to see or edit all the views. I want each department to only be able to See/Edit their own View.
IF this is not possible, what can I do to achieve such results?
Thanks in advance, hope you can help me,
Daniel
Solved! Go to Solution.
May 12, 2020 06:33 AM
See my comments here:
May 12, 2020 06:44 AM
Thank you Scott for your time.
Unfortunately those are not the news I was expecting :frowning:
