Jan 13, 2025 12:44 PM
We are working on a system to track workshops and evaluations effectively. Below are the key requirements and questions we need assistance with:
Subcontractor Logins and Interface:
Workshop Tracking:
Evaluation Tracking:
Activity Records:
Reporting:
Data Integration:
Airtable Feasibility:
Please share any recommendations or tools that could help achieve these functionalities. Suggestions for systems with user-friendly interfaces and strong reporting features are highly appreciated.
Jan 13, 2025 03:13 PM
Yes, all of this is a perfect fit for Airtable. If you’d like to hire an expert Airtable consultant to help you with anything Airtable-related, please feel free to contact me through my website: Airtable consultant — ScottWorld
Jan 13, 2025 08:06 PM
Hi there! Yes to all of the above. I’ve set up a conference management system where individual sponsors have dashboards to see results that show overall performance, and per event. Plus the conference organizer has overall reporting screens. I’ve utilized similar approaches for nomination tracking and scoring.
A formula and relational roll-up fields can be configured as a solution to tracking progress, and you could optimize the workflow with automation that provides status to activity progress and even an email automation (or slack) to send them reminders.
I am open to working with you to build a solution that fits your needs. You can email me at info@consultasolutionist.com or direct message me. Two questions we can open the conversation with are:
How many total sub-contractors will need dashboards?(Each ‘Interface’ can only have 50 total pages inside of it -typically we overcome this by separating interfaces by managers.)
Do you want the sub-contractors to directly interact with the interface? (Sub-Contractors would have to be added to your current Airtable plan, but I have experience setting up read only dashboards where viewers still have some restricted editing access by utilizing prefilled - forms and automations.)
Hope to hear from you soon!
Jan 14, 2025 07:17 PM
Can we create a solo interface for each subcontractor where they can access their specific data?
Yeap, assuming the Interface layout is the same for each subcontractor, you'd just get them to create Airtable accounts and filter it by 'Current user'
Can the dashboard also track attendance and display just the total count of attendees?
Yeap. Depending on how your data's structured you may need to massage the data a bit to get it into the format the dashboard expects though
Can evaluations, workshop data, and attendance records be seamlessly integrated into one system or dashboard?
Should be fine, yeah. Same caveat about massaging the data applies though, so while it could be seamless it could also need more work
Can all the above requirements be achieved in Airtable?
Should be fine, yeap!
If yes, would you be able to assist us in setting this up and configuring the system to meet our needs?
I'd be happy to help with this! We'd take a look at this together to see if we could handle it all within Airtable, and if not we'd integrate third party tools as needed, for example automating PDF creation for the invoices to the subcontractors and logging them within QBO or the accounting software of your choice
