Connecting Filemaker to Airtable using ODBC
Topic Labels: Filemaker
1041 1
decpro350
How do I connect Filemaker to an Airtable database using ODBC. Filemaker can work with available Windows ODBC drivers. What is the procedure?
Thanks
18 - Pluto
18 - Pluto
That is not possible, since Airtable does not support ODBC.
Airtable communicates with external apps through REST APIs, so you can have Airtable communicate with FileMaker Serverโ€™s API, or you can communicate via Claris Connect.
You can also write API calls to Airtable by using FileMakerโ€™s โ€Insert from URLโ€ script step.
Additionally, if you want to migrate your data from FileMaker to Airtable so that you can use Airtable instead of FileMaker from this point forward, you can also export and import any text-based data. Migrating container fields would take extra work.
Hope this helps! I am the only Certified FileMaker Developer and expert Airtable consultant in the entire Airtable ecosystem. If youโ€™d like to hire an expert FileMaker & Airtable consultant, feel free to reach out to me through my website: Airtable Consulting โ€” ScottWorld
