Add data to EXISTING record using Web Clipper
Topic Labels: Extensions
4816 15
Nathan_Beckstea
Is this possible? If so, how?
15 Replies 15
Nathan_Beckstea
So… not possible? You can’t use web clipper to add data to a field of an existing record?
I’m also curious about this. Didn’t everybody get the same email from @Katherilne at Airtable on Jan. 8 with the following update?
  • Web clipper now supports linked record fields , allowing you to select an existing linked record when clipping from a web page.
Great announcement but Airtable failed to update their User Manual to explain exactly “how” that’s supposed to happen.
Anybody?
Dean_Arnold
7 - App Architect
7 - App Architect
What if you’re not clipping linked records. What if you just want to update any old record…
It would be great if you could elect at least one field in web clippers (like URLs or page titles) to act as a matcher.
When the value for the matcher field in the extension clipper matches that of your Airtable, an extra button called ‘Update’ could show up in the clipper.
That way you would have the choice to update an existing record or add a new one.
I just wondered if you know if this is now an option Dean, to use web clipper to add to an existing record?
I was thinking exactly the same, and came across your post, but can’t see any updates since.
Hi Caroline, I haven’t checked the clipper functionality for some some months. I did not find a no code solution at the time.
Has anyone discovered how this works yet?
Hi @Flash-Point
You can add a linked record field to web clipper and then manually browse the linked items. You can’t add new options (which is annoying, same for a select field). Where are you stuck exactly?
Flash-Point
Hi @Databaser
Thanks for clarifying.
I guess I was expecting something more, like being able to add new options, or more importantly update existing records via the linked field. But obviously that’s not the case.
ngalkodjok
So I gather that there is still no option to use web clipper on already existing records?
Does anyone know if that’s a functionality that will be included in furutre versions?
Cheers.
