Importing csv files with 18 digit numbers, doesn't work
430 4
Adisa_Nicholson
  • What I tried to import: 513267577250775049
  • What actually got imported: 513267577250775040
  • Simple terms: The 9 digit at the end of the number, got changed into a 0
The relevant CSV file to import, is below.
name,server id,notes
Ergonomic chair,513267577250775049,
Wooden storage box,,
Wooden pen holder,,
18 - Pluto
18 - Pluto
Right, that will need to be your solution for this. Airtable’s number fields can’t handle numbers that large, and you’re not using it as a number anyways (e.g. performing math on it)… you’re using it as an ID.
4 Replies 4
Are you importing into a number field? Import into a single line text field instead.
It works in text fields but not in number fields.
18 - Pluto
18 - Pluto
Additionally, if you need to automatically import CSV data into Airtable without any manual intervention at all, I demonstrate how to to do that on this Airtable podcast episode. It simply requires using Make's CSV automations & integrations for Airtable.
p.s. If your company has a budget and you’d like to hire an expert Airtable consultant to help you with any of this, please feel free to contact me through my website: Airtable consulting — ScottWorld
