Is there a way to @mention multiple users in a Comment?
  • April 21, 2025
  • 181 views
Forum|alt.badge.img+13
Hi, I have a request to set up a “tag” so that users can @mention everyone in a dept. in one new comment.  I tried doing this with groups.  I created a group made up of 4 users who are all Editors in the base, and gave the group the name “TechGroup”.  I would like to add a comment on a record and ‘@TechGroup’ so each member is notified. So, far this doesn’t seem to work.  Is there another way to tag multiple people in one mention?
Hey ​@Sharon_Visser!
Even if you can tag multiple users individually. -see image below, as far as I am aware you cannot group these together to tag them as a group for them to get notifications individually. I might be missing smth..
A workaround you could use is to have a Group table, and a Users table. Link the different users to the corresponding Group.
For last, rather than using the Comments section, use a Comment Log table, and have the Comments Log table linked to the Groups table. You can have an automation that whenever the Group field is not empty (or similar trigger) an automation will search all users found within such group, and for each of them (repeating group) it will send an email or slack message.
Is this too much for what you are looking for?
Please let me know your thoughts.
  • April 21, 2025
@Mike_AutomaticN It *might* be a big solution for a small problem, but I will try to set up the Groups table and Comment Log as you suggest (in a test base) and see if that might be worth the effort.  At a minimum, I’ll learn something new which is always a good thing.
Thanks alot for your reply!
Sounds great ​@Sharon_Visser, and I would def like to get your feedback once you’ve played around with it!
