I was trying to set up the filter, but I keep getting an error. I also, wasn’t sure if I have to set up another field/fields. I am also not sure if I just need to include some of the fields in the record or all the fields in the record.
@M_k Perhaps I’m missing part of your question here, but I think this could also be done even more simply with the built-in Filters that Airtable provides.
This screen shot only shows some of the fields listed, but I think this gets at what you want. I think this also makes it more flexible if you add more fields later on. You can also change the “Or” to “And” and then it will display records with only blank cells.
I tend to fall back on solutions that I use, and I use a slightly more robust form of the method I suggested here (creating a formula field and filtering on that field) because I personally have a base where the built-in filters do not suffice (the built-in filters cannot handle both “and” and “or” conditions), and I like more information that summarizes what is missing.
Yes. I agree. I did try the filters, only, as suggested by @Matthew_Thomas, but it was not catching all the records. That’s why I was hoping there was another way to “catch” the records.
The formula that you suggested seems to have done the job.
