Create a Base with in a Base
Topic Labels: Base design
1428 2
Charles_Morris
Can you create a Base within a Base?
JonathanBowen
13 - Mars
13 - Mars
Hi @Charles_Morris - the short answer is “no”, but if you can give some more detail on what you are trying to achieve, there might be a way to do that.
JonathanBowen
13 - Mars
13 - Mars
HI @JonathanBowen, thank you for your response. I was trying to figure out the best way to categorize multiple bases within the workspace. I realized that the individual bases would suffice. Thanks again!
