Formula Help, IF; Then
954 1
Luke_Chant
I need some formulas written that should be easy for someone who knows how.
Some IF, Then style formulas. I need 4 or 5 different ones in the same spreadsheet.
Let me know if you can help.
Hi @Luke_Chant, Shoot me an email and I’ll get you setup.
Thanks,
Nathalie
Let’s connect: LinkedIn
