Formula help to match partial email addresses to persona
1874 3
Charne_Morris
Hi. I’m new to airtable, and fairly new to formulas. I’m trying to build a formula that looks at the part of an email domain and based on if a specific word exists or not, enter the persona into another field.
Example
Fields are EMAIL and PERSONA
If the EMAIL domain is @usa.company.com and I’m checking if the domain contains “company” I then want to have the PERSONA be “employee”. If it does not contain “company” I want the PERSONA to be “customer”
So far this is what I have IF((FIND(“company”,{Email Domain}) >=1)“Employee”, “Customer”)
Zollie
10 - Mercury
10 - Mercury
You were close:
IF( FIND("company",{Email Domain}) > 0, "Employee","Customer")
3 Replies 3
Zollie
10 - Mercury
10 - Mercury
You were close:
Charne_Morris
Thank you! You solved my problem. Life is good :slightly_smiling_face:
Realized I had a typo. Make sure you’re doing > not >=
