- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
Apr 27, 2020 01:27 AM
Hey there,
Wondering if you all can help me with a Timezone issue I’m having that’s driving me nuts! I think it’s to do with GMT/BST but I would like any help in solving this because I can’t get it right.
Trying to pair a Mentee and Mentor with each other, and they will live in different timezones, I can get the calendar invites to work, as it’s all based off nice and simple ISO time, but I can’t for the life of me get the timezone conversion to work in Airtable for local time (which I need for numerous other reasons related to communication)
I’m using this formula to convert the time as follows:
IF({Event Date + Start time}, DATETIME_FORMAT(SET_TIMEZONE(DATETIME_PARSE({Event Date + Start time}), {Mentor Timezone}), 'MM/DD/YYYY h:mm'),"")
However, I’m getting a delta across Mentee and Mentor, as shown below in both tables:
Can one of you kind folk help me work out what’s going on?
Mentor View
Mentee View
As you can see, there are 6 columns in each, and the problem is that the Actual time differs from the Calculated time.
- Event Date + Time - The ISO time that is converted to a calendar field
- Actual - What the conversion should be
- Calculated - What the conversion is when using the formula
Is this a bug or am I missing something?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
May 01, 2020 01:39 PM
Time zones can be tricky. It took me a while to figure them out.
Here are some things to keep in mind:
All date/time fields are stored as GMT time internally.
In the user interface, date/times can be displayed as GMT time or the local time for the computer. This is controlled in the field formatting. This works for date/time fields and for formula fields that only return a date/time object (versus a string).
You can set the time zone in a formula field using a combination of
DATETIME_FORMAT
, andSET_TIMEZONE
. Note thatDATETIME_FORMAT
returns a string, not a date/time object. -
You do not need to use
DATETIME_PARSE
because you already have a date/time object. SaveDATETIME_PARSE
for when you want to turn a string into a date/time object. (For example, when converting a text field, or when creating a new date based on a month, day, and year.) -
There is no Airtable formula function to determine the timezone of the client computer.
Here are my thoughts:
You are on the right track by having a field for the time zone for each person. I recommend using a Single Select field for the time zone instead of a text field. That way you don’t have to worry about typos in the time zone.
You have six date/time input fields: three pairs of start/end times. Can you clarify the workflow that requires three pairs of times as inputs? I would expect that each session would have only one date/time input pair, and that the rest of the fields would be calculated.
Consider having a start date/time and a duration as your input fields. Then calculate the end date/time. That makes for is one less date/time input field, and one less field to deal with time zones.
Who will be doing the data entry? Will mentors & mentees on their on their own computers? A single a third party in a specific time zone? Multiple third parties in multiple time zones? This determines whether or not the input fields should be set to display local time or GMT time.
Some people like to set date/time fields to GMT time for everyone, but then they pretend that the GMT time is their local time. I highly recommend against this practice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apr 27, 2020 01:52 AM
Hi @andywingrave,
Why dont you simply use the SET_TIMEZONE({Event Date + Start time}, {Mentee Time Zone})
, why do you need to use all of this formula ? Are you adding the date as a text or as a date field? The IF part I understand (so it doesn’t return an error if the field is empty), but why PARSE and FORMAT?
BR,
Mo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apr 27, 2020 01:57 AM
Hey @Mohamed_Swellam - Thanks for getting back to me.
That’s actually where I started off, but that was so wildly out of sync with what I needed. The If statement only states (If there is a time - i.e. has a meeting been booked), and the Datetime parse was the last hope of a desperate man.
Regardless - I’ve added it in to the last column, above, and you can see that there’s a 2 hour difference between the start time, and your formula. I’d definitely appreciate if someone could point me in the right direction here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apr 27, 2020 02:01 AM
Oh so it didn’t work as I said? :grinning_face_with_big_eyes:
Probably the problem is Use the Same Timezone (GMT) for all Collaborators
. Make sure you use this in all the fields (even in the formula field). Remove the Format and Parse, it worked when I tried it.
BR,
Mo
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apr 27, 2020 02:02 AM
Yep! I’m using that too! Can I see your solution, because I’ve added your solution to the table above, and you can see that there’s a 2 hour difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apr 27, 2020 02:18 AM
That is weird, it is working for me!
this is my base https://airtable.com/shrulkmiRc8REDSfi/tbloTQNhELV3F00R1?blocks=hide
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apr 27, 2020 02:20 AM
That hasn’t worked on your base, sadly - It should be the same as “Mentee Actual Start” - You’re just pulling in the “Event + Start Time”
:pray: :pray: :pray:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apr 29, 2020 09:07 AM
I couldn’t find a solution to this. I emailed support - Let’s hope they can figure it out.
In the meantime, I decided to manage timezones outside of Airtable, as it was causing too much confusion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
May 01, 2020 11:35 AM
Please see formula below as to how this can be accomplished for the specified use case!
DATETIME_PARSE(DATETIME_FORMAT(SET_TIMEZONE({Event Date + Start Time}, {Mentor Timezone}),'M/D/Y h:mm A'),'M/D/YYYY h:mm A')
Hope this helps!
- Mark as New
- Bookmark
- Subscribe
- Permalink
DATETIME_FORMAT
, andSET_TIMEZONE
DATETIME_PARSE
