Help Updating a Field in a Record
850 1
Tom_Peacock
Hi - I am very new to scripting and looking for advice on how to update the existing script.
I grabbed this pre-made script from the Airtable library to create child records. In addition to creating the child records, I was hoping to update a field on that child record as well with an inputted value. Can anyone advise on what updates to make?
let settings = input.config({
title: 'Create child linked records',
description: `For a record in a "parent" table, this script will create some
number of “child” records in another table, where each “child” references the “parent”
through a Linked Record field.`,
items: [
    input.config.table('parentTable', { label: 'Parent table' }),
    input.config.table('childTable', { label: 'Child table' }),
    input.config.field('linkField', {
        parentTable: 'childTable',
        label: 'Linked record field',
async function createChildrenLinkedRecords() {
let { parentTable, childTable, linkField } = settings;
if (
    linkField.type !== 'multipleRecordLinks' ||
    linkField.options?.linkedTableId !== parentTable.id
    output.text('Linked record field must be of type linked record to parent table.');
    return;
// Airtable limits batch operations to 50 records or fewer.
let maxRecordsPerCall = 50;
let parentRecord = await input.recordAsync('Parent record', parentTable);
while (!parentRecord) {
    output.text('You must select a record.');
let newRecordCount = parseInt(await input.textAsync('Number of records to create'), 10);
let newRecords = [];
// Part 1: Prepare the new records
for (let index = 0; index < newRecordCount; index += 1) {
    newRecords.push({
        fields: {
            [linkField.id]: [{ id: parentRecord.id }],
// Part 2: Perform the record creation operations in batches
while (newRecords.length > 0) {
    await childTable.createRecordsAsync(newRecords.slice(0, maxRecordsPerCall));
    newRecords = newRecords.slice(maxRecordsPerCall);
output.text('Done');
await createChildrenLinkedRecords();
here,
add another input.textAsync line to add your text
don’t use “parseInt”, as you need text, not number
the name of variable (like “newRecordCount”) - choose yourself
here:
  fields: {
add your field.
(e.g.)
        "MyField": myVariable
