Help Wanted: Scripting block
1222 2
Brian_Swichkow
Hello Airtable Community,
We’re Airtable addicts and need some help with Javascript.
We’ve looking to append UTM codes to links in HTML blocks.
See our post: Extracting text from between consistent characters
After this task…
We’ve built an economy on Airtable and are at the point of looking for an expert to help us refine the code that got us here. We’re starting to experience heavier loads and would like to make it more efficient and robust.
~Brian
Carter_W
Dear Brain,
Hope you are doing well!!
I’d Glad to assist you.
PM Sent, Please Check.
Very Best Regards
Carter W
Andrew_Johnson1
8 - Airtable Astronomer
Hi Brian,
What you are wanting done is well within my area of expertise and I would be happy to help you out on this.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
