Help with nested IF statement
845 2
Keren_Aarons
Hi all
I need some help with formatting a nested IF statement as I can’t understand why it’s not working. Here’s the background:
I have a {Start Date} field and an {End Date} field - both are formatted as “Date fields”. I want to check the current day - TODAY() against these dates and print out an emoticon depending on the result. I can get this single IF statement to work:
(If the END DATE is AFTER today, then print “ :horse_racing: ” (running!), if not, then print “ :heavy_check_mark: ” (completed!)
IF(IS_AFTER({End Date}, TODAY())=1,“ :horse_racing: ”, “ :heavy_check_mark: ”)
However I want to add a third condition for the future:
(If the END DATE is AFTER today, then print “ :horse_racing: ” (running!), If the START DATE is AFTER today, then print “ :crystal_ball: ” (future!), if not, then print “ :heavy_check_mark: ” (completed!)
So I have this which doesn’t work and throws up an error:
IS_AFTER({End Date},TODAY())=1,
“ :horse_racing: ”,
IF (IS_AFTER({Start Date}, TODAY())=1,
“ :crystal_ball: ”,
What am I doing wrong?
Kamille_Parks
16 - Uranus
16 - Uranus
Try the following formula:
   {Start Date} > TODAY(),
   ":crystal_ball:"
      {End Date} > TODAY(),
      ":horse_racing:",
      ":heavy_check_mark:"
Kamille_Parks
16 - Uranus
16 - Uranus
   ":crystal_ball:"
      ":horse_racing:",
Thanks Kamille!
I just had to add a comma after “ :crystal_ball: ” (so “ :crystal_ball: ”,) to get it it work.
Any idea why my effort didn’t do the trick?
