Help with SEARCH() Formula
7679 2
AlliAlosa
10 - Mercury
10 - Mercury
I am super confused here… does the SEARCH() formula function not work when performed on a Lookup field?
The following formula performs correctly on the table containing the field {Description}, but NOT on the table which looks up the field {Description}.
IF(OR(SEARCH("HINO", Description) > 0, SEARCH("ISUZU", Description) > 0), "!", "")
AlliAlosa
10 - Mercury
10 - Mercury
Answered my own question I guess… I modified the formula to be:
IF(OR(SEARCH("HINO", ARRAYJOIN({Description})) > 0, SEARCH("ISUZU", ARRAYJOIN({Description})) > 0), "!", "")
And now it works!
You can also cast a lookup field (which returns as an array) into a string by appending an empty string to the field. That is, you could modify your original example to read:
IF(OR(SEARCH("HINO", Description&'') > 0, SEARCH("ISUZU", Description&'') > 0), "!", "")
