How do I add the same comment to multiple rows at the same time?
732 1
Larry_Advey
I like the comment functionality and it works great for tracking comments for 1 row BUT when I have data where I need to insert a comment across N rows it is quite tedious to open each row individually and add it in.
How do I add the same comment to multiple rows at the same time? I am looking for a right click and comment option or similar.
Rupert_Hoffsch1
10 - Mercury
10 - Mercury
You can’t add comments to multiple records at the same time. Comments are also not accessible via API, so there is also no extension or script to do this (unfortunately!).
Rupert_Hoffsch1
10 - Mercury
10 - Mercury
