The Community will be undergoing maintenance from Friday February 21 - Friday, February 29 and will be "read only" during this time. To learn more, check out our Announcements blog post.
How to Move Columns in an AirTable Base
Topic Labels: Base design
5778 3
Terry_Liberty
I have a base with columns (fields) in a given order horizontally across the page. I want to move some of these columns so that the are in a different order across the page. How do I do that?
Ha! Too easy. I could have thought I’d tried that.
Thanks.
3 Replies 3
M_k
11 - Venus
11 - Venus
Hi Terry
You just need to go to the top of the column (field name) area and click and drag to were you want to place it.
This works for both desktop and mobile device versions.
Hope this helps.
If so, can you mark it as a solution, so others can find it useful, too.
Thank you,
Mary Kay
Thanks.
Hi @Terry_Liberty
No problem.
Can you mark the solution in my reply, too?
Thanks,
Mary
