Save the date! Join us on October 16 for our Product Ops launch event. Register here.
May 15, 2019 03:25 PM
Hi AirTable Community -
I have a grid with one single select column indicating contributors (Freelance Writers) and another column indicating Word Count (#). The Word Count field will be an integer, but the cost calculation will depend on where the word count falls within a numerical range. I’m hoping to generate a formula that generates the cost of the article based on the word count. It would read like this:
If {Freelance Writer} is “option from single select column” and {Word Count} >=500 and {Word Count} is <=700, Cost “150”
but I am striking out. Any advice on what I’m missing?
Solved! Go to Solution.
May 15, 2019 04:35 PM
I assume you will have multiple options within {Freelance Writer}
and also multiple options within {Word Count}
, so to make that a little less messy, we can use a SWITCH()
function in combination with IF()
statements, or even nested SWITCH()
functions. I think something like this should work:
SWITCH(
{Freelance Writer},
"Option 1",
{Word Count} >= 1500,
300,
{Word Count} >= 1000,
250,
{Word Count} >= 750,
200,
{Word Count} >= 500,
150,
100
"Option 2",
{Word Count} >= 1200,
260,
{Word Count} >= 900,
240,
{Word Count} >= 700,
200,
150
The SWITCH()
function evaluates the first parameter you pass it - in this case we told it to look at the {Freelance Writer}
field - and matches it against the output options you pass it in subsequent parameter spots. In this case, we passed "Option 1"
and "Option 2"
as the possible values of the {Freelance Writer}
field we want to act against.
If the SWITCH()
function determines that the field {Freelance Writer}
matches the output "Option 1"
, it will execute the nested IF()
statement we made right after "Option 1"
– and that nested IF()
is running down possible options for the output of the {Word Count}
field. When one of those conditions matches, you get your final output for the field. I put the {Word Count}
options in descending order (the largest word count threshold - 1500 - first) so that they can be evaluated simply without having to define both an upper and lower limit for each threshold; if {Word Count}
isn’t >= 1500
, then it moves down into the next threshold category, namely >=1000
, and if it doesn’t meet that threshold then it moves down into the next, until it finds a hit and returns your dollar amount.
Hopefully that makes sense enough that you can plug in your own data and expand on it.
SWITCH(
{Freelance Writer},
"Option 1",
300,
250,
200,
150,
100
"Option 2",
260,
240,
200,
150
The SWITCH()
and "Option 2"
If the SWITCH()
isn’t >= 1500
May 16, 2019 09:36 AM
Jeremy, you’re a wizard! Absolutely works:
SWITCH({Freelance Writer}, “Carrie”, IF({Word Count} >= 2501, 650, IF({Word Count} >= 2101, 575, IF({Word Count} >= 1801, 500, IF({Word Count} >= 1501, 425, IF({Word Count} >= 1301, 350, IF({Word Count} >= 1001, 275, IF({Word Count} >= 701, 200, IF({Word Count} >= 500, 150)))))))), “Vanessa”, IF({Word Count} >= 1501, 350, IF({Word Count} >= 1301, 275, IF({Word Count} >= 1001, 200, IF({Word Count} >= 701, 150, IF({Word Count} >= 500, 125))))))
Thank you so so much!
