If, then formula for percentage calculation
1455 5
Ons_Stories
Hi, I’m wondering if there’s a way to do this. I have a table with the category of a used book and the original price. I want to create a formula that calculates the selling price based on the category of the book. So it would be IF category = A then take Original Price and deduct 30% to get the selling price. I’m not sure if I can do all of this in one go with an IF formula. But maybe I can do part of it? Thanks for the help!
Jeremy_Oglesby
14 - Jupiter
14 - Jupiter
You can do this much more efficiently with a SWITCH() function:
{Price} *
SWITCH(
   {Category},
   "A", 0.7,
   "B", 0.6,
   "C", 0.8
5 Replies 5
Hi @Ons_Stories,
Yes you can do that. You would use a nesting IF formula. Something like IF({Category}=A, Price0.7, if({Category}=B, Price0.75, … and so on
And so on.
This formula can be a little tricky, if you need help with it just let me know. I will need to see a screenshot of your table and know what you are trying to achieve with that formula.
BR,
Mo
Thanks, but yeah this didn’t help. It says there’s a problem with the formula and I’m not sure how to fix it. In the screenshot below you’ll see what I typed in the formula. I’m trying to formulate 70% of the Original Price IF Category = A and IF Category = B then 60% and so on!
It won’t let me upload screenshots, sorry
Jeremy_Oglesby
14 - Jupiter
14 - Jupiter
{Price} *
SWITCH(
   {Category},
   "A", 0.7,
   "B", 0.6,
   "C", 0.8
Ons_Stories
That worked thanks a lot!
