Insert values from fields into a record using brackets {field names}
Topic Labels: Extensions
720 0
Jorge_Araluce
So I am trying to do something like the Placeholder variables in the SendGrid pack , but for a field that then i could sync to a Google sheet or send to zapier - The idea is to be able to do a kind of merge , where It could dynamically change the variable according to each record , so it can send/sync a personalized message to zapier or google sheets
This is done in the sendgrid and twilio pack …
SendGrid block
The SendGrid block is part of Airtable Blocks, a Pro plan feature. Blocks let you extend the functionality of your bases: you can use blocks to bring new information into Airtable, visualize and su...
0 Replies 0
