Apr 15, 2020 08:42 AM
Apr 15, 2020 08:56 AM
Do you want to remove all spaces, or only some?
You can replace the space character with an empty string using the SUBSTITUTE
function. It is documented in the formula field reference.
SUBSTITUTE({field name}, " ", "")
Apr 15, 2020 08:59 AM
Thank you Kuovonne it worked perfectly :heart_eyes:
